Posted 6/12/2017 06:55 (#6066547 - in reply to #6066389) Subject: RE: Looking for case 1250 row units
n.c.iowa
I'm assuming beings you still have the meters that you are replacing damaged units. So if your upper side plates aren't damaged (meter mounts) 900- 955 row unit will work.
I think the only two things you have to do are, redrill the seed boot retaining pin, and widen the cutout for the seed boot at the top.
