Torn, I am working to get rid of as many of the monitors as I can and capitalize on what ISObus is supposed to do. To that end, here is what I would like to do: - I am want to get Intellibale working on my NH ISO 560 baler. That would simplify running it on two tractors. First is a Mag200 with Pro700. The second is a NH T6.160 with a Intelliview IV. I currently run the baler via VT on either machine. I also have a spare Intelliview III available with harness just in case I ever have to use the baler on one of the non-ISO equipped tractors.
- I am in the process of installing a Raven ISO node on my sprayer so I can eliminate the Raven 450 and run the sprayer on either tractor via VT without having to move a controller. One of my goals is to implement section control. Am I correct that speed will come from the Pro700 or Intelliview IV when this is done?
Questions: - To implement section control on the sprayer, I need to purchase the TController unlock. Correct? Is that all that is required?
- To get the NH 560 talking to either tractor so that I can implement Intellibale requires the TController unlock as well. Is that correct?
- Is there a software update required for the NH 560 baler? It is a 2016 (40th anniversary Model)
I am currently testing Accuturn on the Mag200. Seems to work pretty well except I am having issues getting it to initiate the turn at the headland or the boundary. Any pointers? I also seem to have a lot of steering corrections on the Mag200 whenever I hit a hole or bump which causes the tractor to roll. Do I need to recallibrate the NavII? Not any knowledgeable PLS guys in my neck of the woods so I typically have to tell the dealers what is needed. Thanks in advance for your help. If you prefer, my email is good..
Edited by d6btex 6/9/2017 17:08
