Search Forums | Classifieds (127) | Skins | Language
kinze 2300 seal kit "GR1003" - 4 inch spin cyl.
   Forums List -> Where Can I find?????Message format
KMech
Posted 6/9/2017 01:52 (#6061498 - in reply to #6060932)
Subject: RE: kinze 2300 seal kit "GR1003" - 4 inch spin cyl.
Missouri
Have your dealer call Kinze. If a machine is down, they can find a way to fill the order. Alternatively, if you have a hydraulic shop nearby, they can probably match up all the seals piece by piece (outfits near me can often do this cheaper than OEM kits). I'm assuming it's an external leak, which means possibly the only piece you need is the rod/gland seal. A third option would be seeing if your dealer could pull that seal out of a kit for another cylinder with a same size rod. Often that is the same part across all cylinders of a given rod size.
