North Bend, NE | I did a new implement with correct rows and spacing, reconfigured muxbus, all 32 seed tube and rpm sensors are showing ok, the rpm sensors count correctly. The strange thing is that I have 3 rows with stuck clutches that plant all the time, when the planter is down and the master switch is off, those rows go up on the bar graph, no pop number though.
I switched back to my 31R15 configuration and redid muxbus again with the same result. It seems like something is backwards but I can't figure it out.
Thanks | |
