Posted 5/24/2017 20:10 (#6035989 - in reply to #6035920) Subject: RE: John Deere 5303 hyd. problem
Remove 3 hoses, remove 3 adapter fittings, remove 1 Allen plug within the pressure port. This plug, when installed forces oil out to the loader valve and completes the loop of the open center circut. The pump would immediately go into a strain if you do not remove the plug and it should stay with the loader for assembly on a different tractor.
