Posted 5/24/2017 15:29 (#6035469 - in reply to #6035410) Subject: RE: CFX750 won't turn on
If you have a voltmeter it wouldn't be a bad idea just to make sure you have 12 volts at the display. (make sure it is 12 volts at the red wire, because 12 volts will be present on the blue wire as well with field iq installed.) If you have 12 volts at the display but it will not power up, it is probably something with your power button more then likely.
