Coldwater, Michigan | Depending on how the 6-18-6 was made wheather it will mix well or not. Get some in a jar and mix some of each. Mix 6-18-6 with the 28%, then mix 28% with the 6-18-6. The direction you mix can make a difference. Also, it might help if some water was added to one or the other prior to mixing. If it is cheap 6-18-6 it might mix fine. If one of the doctored 6-18-6's it might not.
