Malawi | hi you need to enable the task controller on the terminal.
go to the spanner icon that allows you to select imperial / metric / time / date etc. here you can also select task controller under advanced functions. tick the box then go back to your main screen. you should now see a folder icon on the left. in this screen you will also need to set up implements etc as per the steering screen. once you set up a task and implement it will then record coverage when you start the task. its very good being can bus connected as in farmworks you can also see engine load / fuel consumption etc. | |
