Ontario | Have a new to me cfx750 with Omnistar unlock and a dcm300 modem. I can receive Centerpoint RTX fine on satellite and previous owner got it via IP over cellular. Since RTX and RTK are similar accuracy and are both using RTCM3 (I think) format, can I connect to my neighbors RTK IP address for corrections with this setup?
The display does show RTK on the list at least when the RTX subscription is active.. not sure if that goes away after?
Even if accuracy is reduced to rtx or Omni level, that would be fine.
Will it work? | |
