Search Forums | Classifieds (28) | Skins | Language
Fuel Pump Problems
MX255
Posted 5/18/2017 06:33 (#6022717)
Subject: Fuel Pump Problems
southwest Missouri
I talked to mechanic yesterday 3 different times yesterday MX 255 shut dwn from wide open throttle pulling feild cultivator ,, just like you shut key off,
Turn key back on let 12 Volt fuel pump pressurize Big spin on filter for 1 minute an it d start right back up
Any others of you ever have same problem w this lil 12 volt charge pump?
Mechanic told me he made clear hose with pressure gauge for these tractors, acting up like this an when tractor dies,, The fuel hose from 12 volt pump to spin on fuel filter would be empty
Something about check valves in this lil pump go bad an wont build enough pressure
Thanks guys More rain moving in tonight
