Posted 4/25/2017 08:58 (#5981243 - in reply to #5980514) Subject: RE: White 9824 planter questions
I can't comment on tire pressure, but 20" is correct for the central fill, but I believe that is the max pressure you should run. If you have any problems with seed back-filling up the tubes or cracking, you need to lower the pressure.
