Southwest Ontario | Is there anything I can do to help from losing communication with nav controller when starting sprayer. If keying on is delayed for any reason or cycled on the off before the monitor finished loading eg forgot the park brake was on then you have to wait for monitor to power down fully or if you just continue to start the sprayer when the screen is finished loading you will not have communication with the nav controller and will have to turn sprayer off to recycle the pro 700 again which waists a lot of time. Our combine and STX 400 both with pro 700s don't do this. | |
