Missouri | Verify section control button on the VT is green
Verify autoswath button on display is green
(both of these are necessary for ALL section control...boundaries AND overlap)
Then on the display check:
[Home Screen] --> [Big double ended Wrench button] --> {select configuration} --> [wrench button in middle of screen] --> [Automatic swath control button] --> {look at your setting for "outside boundary"} options are turn off, or keep unchanged. | |
