near Mtl, QC | Hi,
I have a green wedgebox (I think it's a seedstar 2?) with all the wiring of a 1760 12-rows doing nothing, and got a project idea. Since I have a 2630 in the cab, I would like to install the wedgebox on my 1590 drill that have 4 seeds sensor and then have one less monitor in the cab. I did plug the 37 pins round connector out of the wedgebox to the drill 37 pins connector (and triple checked pins layout). Then, I plugged the rectangle connector on a harness that have this rectangle plug on one end, and a ISO on the other end.
Now for the testing part, the 2630 does communicate with the wedgebox, because I see a planter icon on the screen and I can setup the equipement, so in my case I disabled vacuum sensor, height sensor, auto speed and let 4 seed sensors. Problem is it doesn't seem to communicate with the seed sensors. I did a seed count test, and it is always at 0.
There is a diagnostic code of 999999
Any idea?
TIA
Edited by Charloz24 4/22/2017 09:50
