| I am putting an Ag leader Integra in a Case STX 350 to control a JD Planter through the Iso bus. However, I cannot see the planter but I can see the tractor on the iso circuit. My problem is the case tractor has its function instance set to 0. I need to Change the tractor function instance to 1 so the Ag Leader system will see the planter. My question is how do you change the function instance in a case tractor. I have a pro 700 I can put in it to change it but do not know where to go. Any help would be appreciated. | |
