nw pa | Had trouble with parking brake not releasing.After checking wiring etc. dove into the micro switches in arm rest. changed the switches and back in business.Feel much better going down the road.A couple of hints to working on it.,If you take the four screws out ,that are inside the flip up arm rest and disconnect hydro cable and wire harness the whole arm with controls comes off. Then you can take to work bench to change switches.
https://talk.newagtalk.com/forums/thread-view.asp?tid=668318&posts=9... | |
