Minnesota | What Voltages are you seeing turned all the way right, steering centered, and all the way left? Also, that kingpin sensor has two circuits going to it, I was told was a low resolution that should go to the tractor controllers to turn off the MFD when turning, and the other a high res that should go to the steering controller, could those have gotten flipped around?
On the Polarity on the deadzone cals I have seen two things happen there, 1 when you test right the system starts turning the machine left ( meaning solenoids are flipped left to right), or 2 ground wire for the left solenoid is actually attached to the right and vice versa, causing a polarity issue.
Edited by IH1486 4/13/2017 22:47
