Whiting, Iowa | You might not want to hear it, but I think I'd take the time to fix it. You don't need the hole in the inside shaft, so take them all out and put the broken one on the inside. If you clean the shafts up good and file down the bolt holes they will usually slide through the bearings and gears pretty easy. I think your collar will wear worse if you don't have a bolt holding it, and they aren't cheap either. | |
