Posted 10/27/2008 21:02 (#492210 - in reply to #492155) Subject: RE: Is 94 Kodiak & 92 Chev PU door glass the same?
I know the older C-70 and the pick-up of the same generation used the same doors and other body parts. I would assume the newer series did the same thing. You may be able to call a Chevy truck dealer and ask them to compare part numbers for each model and see if the interchange. A auto glass installer could do the same thing for you also.
It is my guess that they are the same glass.
INDY
