North Central Iowa | We had the same issue of being really wet here in NC iowa last fall. We run an 8010 with 16r30" Drago chopping head. The combine had the factory installed mud hog and we also ran dualed up 710-38" metric tires. The boss really wanted 800's dualed up but they were not available. So long story short he ordered the 800's and they showed up towards the end of fall and we put them on. With either set we could pretty much go through anything including standing water. We ended up putting the 9380 quad trac on the cart and really had to watch the cart so it would not sink out of sight. It is a kinze 1050 softrac. Also we put cables on the combine that attach to the front axle so that if we got stuck we could pull in the proper place. If you are looking the 700's are for sale just let me know and I see how much the boss wants for them. They only got used on about 350-400 acres the only thing you will need is axle extentions to make them work. | |
