Swift Current SK Can | The shields work about the same as the low drift nozzles and they do get covered in chemical but when it comes to washing them if you do it right after you finish spraying you can rinse it off with a garden hose if it drys it is harder to get off. As far as the sprayer they are a really good and well built. We ran a flexi-coil sys65 which is an older version of that one and put 50,000 to 60,000 acres on it in six years and did not have do anything too it but grease and repack wheel bearing. That series that you are looking at are built better than our 65 was. The monitor is simple and easy to work with and very accurate. I don't think that you will be disappointed with that sprayer. | |
