Posted 1/18/2017 18:49 (#5777196 - in reply to #5777070) Subject: RE: Rusty, stuck shackle bolt
central Iowa
I replaced broken springs on my Chevy 2500. Welded a big nut on a piece of shaft. Nut lets you hang that end of shaft on the bolt.. Shaft needs to be long enough to get you away from the truck body. App;y BFH repeatedly to shaft with extreme prejudice. Continue process on other side. May require frequent breaks for catching breath.
