| seems like whenever the temps get over 85 degrees f ambient temp the coolant runs one bar down from the yellow and the hyd runs about the same maybe 2 bars down but anything over 95 d can't run more than an hour and it gets in the yellow on both hyd and coolant. tractor has 7800 hrs all original. anyone else had the problems or have a solution thoughts would be appreciated. blow radiators out regularly and doesn't seem to help. thanks | |
