Swift Current SK Can | We run two 94c 30'. They are good headers I would find out how many acres that used one has done and what it has cut. If it has been on the ground cutting peas and lentils you might want to look at a new one. Take a look at the bottom of the adapter and see how beat up it is would be a good indication of what it has been cutting. We put Honeybee gauge wheels on the headers this year they are nice when cutting peas and lentils they stop the ends from digging in. Swnd turn up your knife pressure and you should solve the knife stopping problems. If the sch cutting system won't cut there is a chance you should probably not be cutting it. | |
