Search Forums | Classifieds (36) | Skins | Language
9600 dial a matic and reel speed.
EH S. AL
Posted 9/23/2008 19:28 (#467648 - in reply to #467620)
Subject: RE: 9600 dial a matic and reel speed.
Just had the same issue last Friday on my 9600. Turned out to be as simple as the a stuck valve. If you look on top of your return elevator about 2 foot in front of the main valve stack there is a rotary valve similar to a mid-tech auto range valve. Loosen the bolt on the coupler an remove the motor. Then with pliers work the valve back and forth to free it. Put the motor and coupler back on and it should work. Hope that is your problem.
Eric
