| I have a few "templates" set up in Litchi....you can move them around to where you want them positioned. But you can't change dimensions.
300' alt Paths are 90' apart Triggered at 2.5 sec for 15mph.
That seems to get the job done with my P3A RGB and the single Sentera which doesn't have the field of view as the RGB
For someone that flies different fields all the time it can be time consuming to plan a flight.
I wish those w/preflight planners would incorporate radiused turns, and I've spoken with a few about it.
The braking that happens on every corner for a quad is very stressful (over time) on the airframe. | |
