| I would say it is an offset issue then, cause that is what it is doing. What would be the best fix for this? The head is offset to the left about 6" looking out from the cab. Should I put in an offset of 6" left then into the Ez-Guide? Or do I need to move the antenna? It's definately not do to the WAAS because it is consistent and yes I heard about the convergence time also. Thanks for the reply. | |
