Posted 9/11/2008 02:38 (#457181 - in reply to #457055) Subject: Re: Can a ezguide 500 be used to measure acres in fields ?
Netherlands
If you drive your single headland just across the field border, make sure you're implement width is about the width of your tractor. For calculating the area the EZG250/500 takes the outside L or R of the implement (depending of driving clockwise or anti-clockwise).
