Posted 9/6/2008 22:07 (#453566 - in reply to #453275) Subject: RE: Coast Guard Differential Corrections
IA
The new baud xxxxx confirms that something is not talking between the InSight and 3000/3100. It appears to be a cable/connection issue. Have you checked your cables for broken pins/loose connections? Under the Setup and GPS/Guidance menu are you able to select your differential source or select Port A/Port B options? Have you tried force TSIP connection?
