Can GGA signal & WTG be exctracted from the serial connector on a CIH AFS600?
torn
Posted 9/1/2008 13:34 (#448413 - in reply to #448350)
Subject: Re: Can GGA signal & WTG be exctracted from the serial connector on a CIH AFS600?
roaming
No. You cannot get GPS out of the 9-pin connector on the Pro600. You will need to get GPS directly from the 252.
