| Kinzeman- If it was my choise I would lean towards the Insight. You would have the capabilities to variable rate with the insight if your planter is equipped with hydraulic drives. You can also use the insight to control kinzes (tru-counts) electric or air clutches, then you would also be able to set your planter up with direct command to control your fertilizer. Then you would also be able to use the insight in your sprayer as well. For your combine you could purchase a kit to put it in there as well and you would have your site verification maps from planting that you could use to track how each variety yeild's across the field. Seem more economical to go with the insight and have the capability to use it all season long. | |
