Posted 8/12/2008 11:48 (#433639 - in reply to #433630) Subject: Re: AFS 600 implement switching with remote valves
roaming
no can do on the potentiometer (at least right now). The combines do use a pot to track feeder height (and the planters use one to track toolbar height), but the signal goes on to the CAN bus, so unless you can figure out a way to convert an analog pot signal to a CNH CAN message, you're stuck. I've heard rumors that a "generic" work switch will finally be available this year, but haven't seen anything yet.
