Posted 8/10/2008 21:49 (#432579 - in reply to #432096) Subject: Re: EZ 250 & cables
Sunnyvale, CA
the EZ-Guide 500 outputs 12 volts to the antenna. the EZ-Guide 250 outputs 5 volts. The Ag132 High-Dome Beacon antenna can work at a voltage up to 10 volts and you will let out the smoke on that antenna if you connect it to the EZ-Guide 500. It may work for GPS if you connect the Ag132 antenna to the EZ-Guide 250.
