Search Forums | Classifieds (97) | Skins | Language
T2 calibration on EZ-Steer ?
COdrylander
Posted 8/20/2006 08:54 (#37347 - in reply to #37211)
Subject: RE: T2 calibration on EZ-Steer ?
NE CO
Back to Mike's question, is there a way to manually input the T2 correction factor. Sometimes when you try multiple tries at calibration, it would be nice to just put in an average value, and not keep repeating the calibration till you find one close to what you thik it should be. And as Mike mentioned, sometimes it seems as if it is off in one direction and it would be nice to tweak the value manually.
Usually my values are around 1 deg, but I think that is mostly a function of how level the T2 unit is mounted if I understand how it works correctly.
John
Edited by COdrylander 8/20/2006 08:57
