Where Lewis and Clark finished the rum | Got a data stream plugged into Sitemate VRA's Raven protocol today - log without control - and get a themed real time map. However, I seem only to be able to log the "rate" column, when in fact, I want to log the "rx rate" column. Is there a way that I can do this, using SM VRA??
I tried using VERIS protocol, and get the appropriate values for shallow and deep, but again, I seem only to be able to map the "shallow" value, not "deep. Is there a way to to map "deep" instead??
Thanks, Chuck |
