I believe you are asking if you can really 'get down' in there! 30 inch rows, maybe a little wider on the wheel track is going to be impossible to 'fly down'... Fall down, sure! getting back out, no. But if you mean if the camera can 'see' from up above, if you have a flat, then yes! You'd have to maneuver around to get a good angle looking downwards in the wheel track. I got mine when we were about half don harvesting, and that is the first thing I used it to test! Sure, dried up corn is pretty easy to 'see' into, but I thought we'd be able to even when full green. Keep the bird above the pipe!!! |
