I am talking on a per row basis to shutdown the autoswath when combineing and not talking anything about autosteering on a combine. It justs adjusts the acres per swath to make your yield map for accurate. I was combineing 6 rows and when I went down to 5 rows the Insight would not change over to 5 rows at the same time by itself. or it would jump back and forth between 6 and 5 rows. So I just adjusted my headwidth manually instead of useing autoswath. On a sprayer you are not running 30 inch sections, I would bet you are running sections in the 10 feet plus ranges so a waas is good enough for that. I have sprayers on WAAS with autoswath also. Just like when you plant and want single row shutoff, you need HP/XP or RTK. I did have a planter on WAAS with two row section shutoffs and it works good, but for single row I would expect it to work just like my combine did. Maybe I needed to adjust the overlap/skip % when combineing? Anybody use WAAS and autoswath in corn and think it worked good? Ron I am going to email you about your Front boomer this a.m.
Edited by agboy 7/25/2008 08:27
