SE IL | yes you can survey a path, as in a tile run or a surface ditch without the intellislope module.
You can also create a topo map in the integra or versa without any extras besides rtk.
Yes you can export the topo maps.
I think that advancedis a 1500 upgrade over basic, with a large maintenace fee.
Water management for sms is an additional 1000 or so.
unless you are wanting to go full bore designing pattern tile layouts, the water management add on for sms is not absolutely necessary for tiling. | |
