Sunnyvale, CA | Some gyros are more sluggish than others to start at power up and if your EZ-Steer gyros have this sluggish start problem, even if you have good power to your EZ-Steer, your EZ-Guide will show a red screen T2 fault. When the power is cycled, the gyro(s) powers up correctly.
If your EZ-Steer shows this symptom, you can send the unit to AgExpress and ask for the T2 error at power up modification. With this change, when you have good power to the EZ-Steer, it will power up correctly and not show the T2 fault. You might have to go through your dealer to get the unit sent to AgExpress. | |
