I ran into problems yesterday saving shifted lines. I was spraying and I was shifting the planting lines to match the sprayer width (30' planter and 90' sprayer). I have done this in the past with no problems, but yesterday something was not working. I would load the planter line and then shifted in the needed direction 30'. I then saved the line with a new name for the sprayer. But, if I reloaded the new line, it came back up in the old position without the shift. I had this happen in several fields on several different lines. This was on an Insight Nav2 system with direct command. The Insight is on 5.1 with 4.51 in the Nav2. I am at a total loss as to what was going on. I have saved shifted lines before and it was worked fine. Has anyone else seen this? |
