north central NE | The idler hub on the front of the baskets break about as fast as I put them on. It spits the dust cap off almost immediately, and pushes the seal out. This is apparently because the hub is flexing. Then the hub breaks between the bearings and I usually just run it that way for a long time. The bars the teeth mount to appear quite straight. Anybody else have this problem and figured out how to solve it? Somethings bent, but what? | |
