Posted 6/25/2008 20:31 (#404463 - in reply to #404398) Subject: Re: caseih sprayer 3185
North Dakota
Check the switch and fuse for the load share solenoid. Then have someone hold the load share switch down while you check to see if the solenoid will pull a screwdriver or other steel item to the core. The switch only works when the button is held down. also it will share diagonally opposed wheels.
