Posted 6/22/2008 12:15 (#402419 - in reply to #402206) Subject: RE: New air ride seat in magnum
Boone, Iowa
Do not run a jumper hose. I had a 7120 several years ago that had a hyd seat already removed when I bought it. That first spring, I had problems of low hyd flow when trying to run a vac planter. Found the jumper hose under the cab that was causing a high pressure leak. Capped the fittings and fixed the hyd flow problem.
