Posted 6/19/2008 07:54 (#400668 - in reply to #400213) Subject: Re: Problems with AIM sprayer command system
North Dakota
It is in the owners manual, if you spray too slow or with too large a nozzle you will get diagonal srtipping because the pulse length is less than 33%. To fix it go to www.wilger.net and go to the tip wizzard and pick the correct tip for you droplet size, gallons per acre and speed.
Also if you are spraying too close to the ground it will do the same thing.
