Search Forums | Classifieds (30) | Skins | Language
EZ Boom Rate Problem
wresfar77
Posted 6/14/2008 01:15 (#397132 - in reply to #397095)
Subject: RE: EZ Boom Rate Problem
Is your speed sensed by radar or from wheel speed? If its wheel speed the radius of the tire can be a little different when fully loaded after some of the weight is removed the radius of the tire can change significantly especially if the pressure is a little low or you are on soft ground.
