Manitoba | Does anyone have any experience installing the EZ-Boom in these sprayers. Sprayer is a 1999 Case SPX 3185 using a Land Manager II rate controller. The intent is to replace the Land Manager and install an EZ500 and EZ-Steer+EZ-Boom
Does Trimble have an adapter cable so that we can use the existing wiring harness, or do we need to completly replace the exisiting harness with one from Trimble. I understand that some of these sprayers use the raven 460. Did Case use the same main wiring harness for both types or are they compeletly incompatable. If so is there a kit ro replace the main wiring components or do they have to be ordered piece by piece. If you have any information that you could share in regards to these sprayers I would be very grateful.
Thanks in advance. | |
