Posted 5/16/2015 19:27 (#4574149 - in reply to #4573693) Subject: RE: JD sprayer app rate running low, numbers don't match?
West central ND
I don't have a JD but can you set a minimum flow rate? I had an issue with my Agleader. When slowing at the ends it wouldn't recover. I changed the minimum flow rate. Or what is the pressure when it is just agitating? Could you have a pump problem?
