Posted 4/27/2008 01:06 (#366287 - in reply to #366252) Subject: Re: 500 and EZ-Steer?
North west MN
I guess I have never seen one set that low on angle per turn. The lowest I have ever used is 12. Have you tried raising the freeplay numbers. Also make sure you have the antenna to pivot point measurement right and also the antenna height measurement set. I sure you have played with the aggressiveness.
