Posted 4/26/2008 18:57 (#365995 - in reply to #365788) Subject: RE: First time out with Ez-steer and the 500
Camrose, Alberta
alange summed it up.
One problem I have is my air-drill does not pull square. Either the ceter of drill is not inline with the drawbar or one side seeds a little deeper and therefor the drill pulls to one side. To correct the problem I moved my antenna about two inches to the side of the tractor centerline, rather than setting a implement offset.
