roaming | This feature is not currently available in v7.5 AFS software. v8.0 AFS software will have the Tag setup feature again, but the Pro600 won't actually be able to import them until a future display software release.
So for this spring, you'll have to create all Tags in the display itself.
However, if you're doing varieties, you can set them up as Products (instead of Tags), and export the Products to the display. You can do this now. | |
